You'll need at least 5mm (Seven typically puts in 10mm) above the stem so the steerer protrudes slightly above the stem. If the steerer is below the stem, the compression plug will likely be situated lower than the stem. As such, the stem clamp force will put pressure on the unsupported carbon steerer instead of the compression plug.Hi All,
I have a question about the Seven 5e fork.
I have 10mm spacer below stem and 10mm above stem. Can I move my stem up (20mm spacer below stem, no spacer above stem)?
'emailed Seven but no reply as of yet.
