Sis
randycr said:
Hi, I just acquired a specialize epic and im trying to put it back together. the shifters [shimano600]moves but do not click into place. I put on new cables on it already. Do i need new shifter?
Assuming downtube shifters? If so, indexed shifters would have a little ring around the base of the shifter as you're looking at the bike from the side, and that ring would have the letters SIS (Shimano Index Shifting). If you don't have that label, then you have friction shifters. If you do have that label, it is possible that the shifters were switched to friction mode. IIRC, you can twist the D ring or something to go back and forth. Also, they could just be gummed up, in which case a nice blast of solvent while working the levers through their range should sort things out.
