1 - 5 of 5 Posts
Is there any tricks to keeping the shifters working in cold weather? Or is it time for new shifters?
Try using a thinner lube. I had the same problem and switched the type of lube I was using. It fixed the problem for me.
Standard fix
The standard treatment would be to sluice your levers with WD-40 while shifting through the gears a few times. This will thin the grease a bit and remove a bunch of gunk that has likely accumulated in there. If this works, you should possibly follow up with a thinner lube - TriFlow works well, among others.
NeoRetroGrouch
I would guess that it is more likely the lube/gunk in the housings. Does it shift in one direction and not the other? - TF
1 - 5 of 5 Posts
