I had a chain installed Friday and have had a strange shifting issue since. I have a 50-34 chainring with a new 12-27 cassette. When I rode the bike for the first time since the chain was installed, while on the 50 tooth and middleish of the cogs (17 or 19 tooth?) the chain would start making a loud (constant) rubbing noise one the one cog until I shifted to the next. Sometimes it would jump over the one tooth. When I was in the 34 tooth and went through the gears, there wasn't a problem.
I then changed the cassette to an 11-23 and everything worked as normal. I put the 12-27 back on and played with the rear der adjuster a bit both loosening the cable and then tightening it but still have the issue. I made sure the cogs were in the correct increments. Any idea what could be causing it and how to fix it?
Thanks in advance.
Thanks in advance.
