1 - 18 of 18 Posts
Newbie here and mostly ride on flat roads, but just started to climb some hills. I was told that the best place to put your hands on a descent is on the "drops". BUt my fingers are too short to grab the brake levers. A guy I was riding with today said that I could buy shims to adjust the brake levers so that they get closer to my fingers. Can anyone tell me what these are called and are they usually readily available at bike shops? On-line sources? Thanks in advance for any input!
Cycling induced anoesis
You don't specify the make/ model of your brake levers, but this is probably close to what you're looking for.
http://www.thebikefactory.co.uk/productdetails.asp?productid=40596
And more here:
http://www.specialized.com/us/en/bc...nentsRoadBrakeLevers&eid=5135&menuItemId=9305
Fax Transport Specialist
You can find them on amazon.com as well if you search for "shimano lever adjusting block." I've been thinking about getting some but wasn't sure what size would be appropriate.
might be a while before i'll have time to get a picture, but it looks great. I bought the one made by Specialized for the Ultegra. It looks stock. In fact, they do come stock on, ahem, women's bikes. I went to a Trek store and saw the shims on the actual bikes and it looked identical. They work great too! Simple design, double sided tape to install and very simple as long as you don't misalign it because then you mess up the adhesive backing. Good luck!
bahueh said:
a set of compact handlebars would likely eliminate the need for shims...however more expensive obviously.
How so? Compacts come in a variety of shapes/ styles and change reach/ drop, but how is the distance from bar to lever minimized?
Not being argumentative, I'm just not seeing it. :eek:
Fat'r + Slow'r than TMB
The shims almost completely disappear. I have installed them on my wife's ultegra brifters and they work great. Got her about 1/2 inch more control with her fingers.
Can you take a picture of it, i would love to get closer to my levers too
Resident Curmudgeon
Me neither.:nonod:
agm2 said:
Also check out your lbs, they may have a whole bunch laying around that came stock with bikes. I know I have two or three pairs that came with bikes and the customers didn't want them so they left them with us.
This is true. However to OP: make sure you know the exact model number of your shifters and get the shims made for those. I actually got a couple of free sets from a couple of local shops, but they didn't fit. I think they were giving me 10 speed Ultegra units, when I have older 9 speed stuff. I ended up ordering directly from specialized. I think they cost $10. They should be $1.50 (or better yet, free from shimano), but that's cycling.
I'm very happy with the shims. They work as advertised, are virtually invisible (as the photo shows) and were dead easy to install.
My girlfriend is in the same situation. We just picked up a Cannondale CAAD8 Feminine Tiagra/Sora mix.
The thing is...she has really small hands. On the hoods, she cannot get enough leverage to even slow down the bike. Unless you have medium to large hands...the Tiagra levers will cramp your hands in no time. She will also accidentally brake when trying to shift. I can't seem to find a shim for Tiagra...only 105/Ultegra.
The only solution I can think of is to run a bar top brake lever in addition to the existing levers.
1 - 18 of 18 Posts
