BlueMasi1 said:
From my perspective it's all over priced -- not just Shimano or Campy. $200.00 shorts, $4000.00 frames, $75.00 tires. At one time I think the sport was exclusive (in the states) simply because few people knew about it. No it's exclusive because few can afford it.
BS! Pure BS! The expense of bicycling is no worse than any other specialized sport: golf, climbing, scuba diving, whatever. There is a premium attached, to some degree, to items associated with the top end in those sports. Your examples are complete horseshite, since they either presume or are intended to make people think that the only quality bits are $200 shorts, $4000 frames, $75 tires. You're completely daft if you think that's the case, and you certainly aren't cycling aware to any substantive degree.
FYI, my frame is exclusive, hand built out of an exotic metal, and it didn't cost the $4000 you whine about. About half.
You also fail to recognize that some of the expensive stuff is stuff that outperforms its cheaper competitors. It does happen you know.
At any rate, if you're unhappy about the unholy price of cycling, then by all means, only by your bike kit at Walmart.
