I have a 1994 Shimano RX-100 crank, 7 speed, 42/53 that I want to replace with a 39/53 if possible. What are my options? Do I need to find a used crank or are there any new ones on the market that will work with the rest of the drivetrain?
Most cranks that came with a 42 small ring will not fit a 39. They had a 144mm bolt circle diameter vs. the current standard 135 or 130. You can pretty easily tell by looking at the small chain ring: if the chain ring bolts are just about touching the chain with the 42, that's all the smaller that will fit.pmf said:Why don't you just buy a new set of chain rings. Actually, all you need is to replace the 42 with a 39 and you'll have a 39/53 (sure it wasn't a 52 tooth ring?). Any chain ring will work fine. I don't think I'd run out and buy anything real expensive since this was the group below 105 at the time.
Kerry Irons said:Most cranks that came with a 42 small ring will not fit a 39. They had a 144mm bolt circle diameter vs. the current standard 135 or 130. You can pretty easily tell by looking at the small chain ring: if the chain ring bolts are just about touching the chain with the 42, that's all the smaller that will fit.
The only difference between RX-100 and 105 of the time is the finish on the crankarms. The RX-100 was clearcoated and the 105 was painted silver. I have both and they look the same, measure the same, and weigh the same (within 5 grams). The rings are identical in every way, down to the engravings and "Shimano HG" sticker on the big ring.pmf said:I don't think I'd run out and buy anything real expensive since this was the group below 105 at the time.
I used to swap 39's and 42's all the time. Its a standard 130 mm diameter ring.Kerry Irons said:Most cranks that came with a 42 small ring will not fit a 39. They had a 144mm bolt circle diameter vs. the current standard 135 or 130. You can pretty easily tell by looking at the small chain ring: if the chain ring bolts are just about touching the chain with the 42, that's all the smaller that will fit.
Oh of course they WORK fine, it was just an observation. I replaced my RX-100 with NOS 105 kit of the same vintage just because I was appalled by the condition of the crank arms. Of course the rings were exactly the same so this wouldn't help the OP's desire to change that, but as ohvrolla mentioned, it would probably be cheaper to pick up a complete crank and pilfer the rings than to buy new rings.pmf said:Yeah, his cranks might not look pretty, but they probably still work fine.
He only really needs to replace one chainring. A 39 is $25 and a 38 is $35 at Excel. I find it hard to believe you're going to find an entire crank set for $25. Sounds like he wants to do it himself, as cheaply as possible and isn't an experienced mechanic. So I'd vote for changing the ring.ohvrolla said:I had a 53/42 and wanted to go to a 52/39 and it was cheaper to buy a Octalink Shimano 105 crankset than to purchase chainrings. Just robbed the chainrings off of it and put the arms up for safe keeping.
