I don't ever lube new cables/housing. All it does is cause dirt and grit to stick to the cable and then get pulled into the housing.Grease the derailer cables or not? I have seen references both ways, some saying no grease required and others saying to grease them.
yup, I does more harm that good in my experience.I don't ever lube new cables/housing. All it does is cause dirt and grit to stick to the cable and then get pulled into the housing.
^This^ You have to look to be sure you cut off the correct end when fitting it.sp41 housing is pre greased
