1 - 9 of 9 Posts
Hi there,
Trying to set up my bike for France in July.
I've usually got the 7800 Dura Ace gruppo on but I've made some modifications.
I've replaced the crank with a 50/34 Compact Ultegra SL.
Got a 11-28 SRAM Force rear cassette.
New Dura Ace 10 speed chain.
My question is will a rear Force derailleur work with the Dura Ace shifters?
If not, will a medium cage Ultegra rear derailleur work even though specs say the max is 27T?
thanks!
From what I have read, it should work, however not sure how well. A few months ago I thought about getting the 11-28 cassette and it was supposed to work fine with the DA stuff.
I thought the pull was different and it wouldn't work.
Cyclist
AKAIK, the Force derailleur WILL NOT work with DA shifters.
The Ultegra rear mech should work OK with the 11-28tooth cassette.
no...
A SRAM RD will not work with Shimano shifters. The cable pull is not even close to the same.
What matters for the RD is actual wrap capacity. You have a 33T wrap, but the 34/11 would never be used and neither should the 50/28.
I would check the chain length in the 34/12, making it as long as possible. If the chain does not hang loose or rub on the cage, any amount of chain tension is enough. Then check the 50/28. Most likely it will work, even with a short cage RD. Any Shimano RD with more wrap will certainly work.
Before switching to SRAM gruppos I ran 12-28 and 11-28 on both Ultegra and DA RD bikes. It worked just fine with a compact crank up front. I had no shifting issues.
Carbon Fiber = Explode!
There's a pulley available to mix and match pull ratios. It's like 30 bucks.
bleed_oil said:
Hi there,
thanks!
The cassette and chain will work fine.
A SRAM RD will NOT work with DA shifters.
A Ultegra SS cage will work as long as your chain is as long as possible and you don't accidentally shift into the big ring/big cog combo.
It would be better to get a long cage Ultegra SL. You can forget what gear you're in too easily climbing alps.
'brifter' is f'ing stupid
bleed_oil said:
Hi there,
thanks!
not sure why you'd want to buy a sram derailleur when you have a nice one already...but this works great http://jtekengineering.com/shiftmate.htm check #5 at the bottom. as someone stated (c-40?) you won't go 34-11 or 50-28 (or at least shouldn't...much...) so you should be fine w/ your short cage DA rr der.
1 - 9 of 9 Posts
