1 - 7 of 7 Posts
I have a Shimano XTR 9 speeds RD-M970 rear derailleur(short cage) and would like to use it for a XTR 9 speeds 11-34T cassette.
Is it a workable combo ? Or do I need a RD-M971 instead ?
'brifter' is f'ing stupid
Max cog is 34, so that's good. Capacity is 33, so you need to figure that out.
Carbon Fiber = Explode!
When it comes to MTB derailleurs, never buy short cage.
That's just stupid. If the spec is correct for the application, why not?
'Capacity is 33'....Do u mean the front chainring max. is 33T ?
No..."capacity". The difference between the small cog/large cog + the difference between the small ring and large ring. For example:
11/34 cassette: difference is 23 teeth
50/34 compact crank: difference is 16 teeth
23 + 16 = 39 which is obviously more than the capacity of 33 for the GS short cage derailleur. You'd need the SGS long cage, which has a capacity of 43.
If you were running a single chainring you'd be fine w/ the GS and it's shorter cage, contrary to the incorrect advice provided by the other guy i quoted.
Thanks for the valuable input.
Yes, I'm planning to run a single ring(28T or 32T) in the front. :)
970 is Rapid Rise, 971 is regular small cog normal.
If you are sure you have a 970, then get a 970 with a longer cage, not a 971.
I use a 971 short cage on my commuter. 44/30 985 crank and 12/27 DuraAce cassette. Works great.
1 - 7 of 7 Posts
