Shiv Tri into a single speed "fun" bike....need some help on how this works...
859 Views 2 Replies 3 Participants Last post by  Lelandjt
So this may sound a little crazy, but I have a few questions. I have an old Shiv Tri frameset that I have laying around, and I was thinking of ways I could set it up to use it for fun. First thought was to build it up as a road bike similar to the Robert Egger lunch ride design.
But then I was wondering, could I set it up as a single speed bike, and only use or install the rear brake. Only reason I say this is because I think it would look a lot cleaner aesthetically without the front brake installed. Again, I am not going to do anything crazy on this bike, just some casual joy rides. I would think the rear brake alone would be suffice? I am assuming the single gear set up can still use typical road wheels? As opposed to a fixed gear set up which needs some sort of different adapters to work with the road bike dropouts?
Again, might be a pipe dream here, but just seeing what's possible. I am not familiar with fixed gear or single speed set ups so wanted to ask everyone else.
1 - 3 of 3 Posts
Running just a rear brake on a single speed is a poor idea. Having just a front brake would be better. Your braking efficiency is roughly a 70-30 split. It would be different if you set it up as a fixed gear as you could use your legs for braking.
Does the bike have horizontal drop outs?
Sent from my SM-G920P using Tapatalk
And yet there's all those beach cruisers running around with only a rear brake and very few front brake only bikes. I say turn it into the aeroist beach cruiser ever!
Use a chain tensioner designed to single speed a MTB to handle the chain slack from vertical dropouts.
1 - 3 of 3 Posts
