1 - 20 of 22 Posts
Is there any problem with cutting a 330mm seatpost down to 240mm?
I saw that a Thomson Masterpiece was available for a good price but it it's at the longer length.
Has anyone done this?
Banned forever.....or not
After the cut, it might be wise to bevel the end a little, with a file.
Mehpic
yes- use a file, not sandpaper. MUCH more better.
I'd guess that you could treat it like an aluminum/steel fork steerer and use one of these fancy things if you were truly picky.
Steaming piles of opinion
Before you cut, measure from the bottom to the minimum insertion line. Figure where you want the new minimum line to be (nearish the seatpost collar at your desired height) and measure back down to your cut line. Do the mechanicals as described by others, and done.
n00bsauce
Cut it with whatever you want. Hack saw, tube cutter, torch, whatever. Just make sure you have the same amount of post inserted as the minimum on the original post. Really doesn't matter whether you bevel the end or not or whether there are burrs or not as long as it inserts and slides in the seat tube properly. I've cut several over the years, no problemo. Of course, if there's a burr that causes it to catch in the seat tube it has to be removed but otherwise, no one will ever see it and how it looks will never make a difference.
Roadie with unshaven legs
DieselDan said:
Use a tube cutter.
This won't work very well. I had an old junk seatpost laying around that I was messing with one day and decided to cut off the scarred up end so that I could use the good tube for some project. I used a tube cutter to score the aluminum then decided to cut it through. First of all, it would have been a lot less work using a hacksaw to cut it. Second, the tube cutter works by displacing the material, basically pushing it aside. When the roller wheels on the other side roll over the displaced aluminum, it flattens it. What happens is that you will end up with a raised but of aluminum at the cut that you will need to grind down with a file or something. Not only that but when the tube finally breaks it leaves a really jagged edge on both sides that requires a lot of attention with a file in order to prevent you cutting your hands open on them. Use a hacksaw instead.
I recently saw a Masterpiece at the LBS. Like the Thomson Elite, this post had the elliptical I.D. with a thicker wall on front & back. In addition, the shop manager also thought the internal profile varied along the length of the Masterpiece (sort of like a butted frame tube) to shave off more weight.
Assuming this is true, I would proceed with caution. By removing ~3.5" from a post designed for MTBs, you could then expose a thinner walled section to a clamping or shear force it wasn't designed to handle. I'll admit, an unlikely scenario but this is an extremely light weight component engineered to the absolute limit. Best to be safe and pose the question directly to Thomson.
Paul
n00bsauce
Yes, a Thomson post is elliptical on the inside to save weight and still keep it strong. Tubing cutters would have more of a problem cutting them than a hack saw but they would still work. The tubing is consistent top to bottom on the inside so you can cut a Thomson with no problem.
What is the minimum insertion depth on the Thompson's? I was looking to buy one off of ebay but its already cut and I want to know how much post I will have left. What is considered the normal minimum insertion depth?
The thomson masterpiece is such a light post that cutting it shorter will save very little weight. I'd leave it alone, unless it is too long to get it in the frame. If you cut it, you may limit it's use in the future in a different application. A 4" section of that post will weigh maybe an ounce.
1 - 20 of 22 Posts
