1 - 14 of 14 Posts
chrislh said:
i noticed that pretty much every pro on TV wears bib shorts. what's the great advantage or why do they?
It's a comfort thing. I started wearing bibs about a year ago (found some on a killer sale). Ever since then, I hate not wearing them. The elastic waist (on most shorts) can be uncomfortable on longer rides. The elastic starts to cut in a little too much. With bibs, as long as they are cut to fit your torso correctly, fit more comfortably. I now have 3 pairs (one are knickers), and 2 more on the way (new team kit, Hincapie bibs).
Bibs only have one downside... peeing. I've heard some people pull the bibs down in front and lift over, that's a crock of sh*t unless you're John Holmes... most (as the pro riders do) lift the leg and pull out from there.
I suggest finding a good sale on some bibs (Salini's can be found reasonably priced) and try them out. The only time I wear regular shorts now is if I'm just out running errands and throw them on under regular shorts (going to the market and need pockets) or if I'm just doing a short spin on the rollers.
thanks konaman, if i wear a med. in shorts then a med. in bibs should be ok? i am slender build, if that matters. yea i heard peeing was a pain. no porn star here, so i guess i'll try the roll up method. thanks for the reply
Height is the most important factor in bibs sizing, I wear Medium shorts but am 6'2" so I need atleast a Large in Bibs to get the right length in the suspenders.
In both pairs of my bibs (Voler for the RBR kit and Giordana for the CTS kit) I could easily pull the front down to pee when going normally. trying to go while riding would be a different story but really unless you are a pro then you really don't need to do that and would be at risk of getting a ticket or worse if you do.
HyTek *******
alienator said:
But isn't it important to you where the shorts are made?
Chinese slave laborers are doing wonders with Lycra these days! But to add my $.02, I got on the bib bandwagon this year and will never go back to regular shorts. I'm 6'0" with a 38" waist, and wear a Voler XL.
Steaming piles of opinion
Multiple choice...
I pee over-the-top, so
A) I missed my calling in life
B) My wife doesn't lie to me when she wants something
C) It's a little about cut, and a little about technique. Bend at the waist, pull down, tug up, pee.
:D
Roll up and tug down takes far more johnson than over the top, unless you don't mind pee running down your leg.
Bibs are better...
Actually just wore my new bibs for the first ride today! Can now say that hands down, bibs are much more comfortable, and offer a better fit than shorts. Not that much more expensive either.
1 - 14 of 14 Posts
