1 - 5 of 5 Posts
I've finally decided to dabble at wheel building/ spoke replacement and took some bent spokes off a OP wheel built by Excel that I've been meaning to fix. When I unscrewed the nuts off the spokes I was expecting to see some trace of spoke prep around the thread end of spoke and nut but I see absolutely nothing. Shouldn't I see some spoke prep?
Visible spoke prep
It depends on what the spokes were prepped with. Properly tensioned spokes don't need any kind of locking compound, so the only prep they need is some type of lubricant (grease or oil).
I tried my hardest to find 'linseed oil' in stores. I couldn't find it any where (not even in grocery stores).
I just ended up using Pedros Road Rage lube.
Art supply store should carry linseed oil as it is used by oil painters. If you don't have an art store nearby try Micheal's.
Try art supply store (Micheal's in Suburb) as linseed oil is used by oil painters.
1 - 5 of 5 Posts
