1 - 5 of 5 Posts
Is there any difference between the ease of pumping up a Schraeder valve tube or a Presta valve tube, especially with a mini-pump? (One of those pumps that's about six inches long.)
Some of the mini-pumps I've seen only work with one valve type or the other.
Should be no difference. Volume of air required to reach desired pressure will be the same. Process of attaching pump to valve is essentially the same.
Devoid of all flim-flam
For my money, it's presta all the way. The Schraeder has a spring to close the valve, something that really causes hassles when your're trying to keep the pump attached and locked onto the valve.
mini or floor pump, presta is easier to use for high-pressure low-volume tires. That's what it was designed for. As mapei said, the absence of a spring is the crucial difference. You don;t lose air when you disconnect the pump.
Resident Curmudgeon
^^^^^Exactly^^^^^
1 - 5 of 5 Posts
