Yeah, taking everything I can find. Something like that, some zinc lozenges, and Zyrtec D. Kind of clears me up enough that I think I can do it.This helped me lessen the impact of a cold.
Airborne Health Formula Vitamins and Minerals to help support your immune system
Or at least felt like I did.
HTFU?I have nothing constructive to add.... I asked my daughter what advice she might have though, she mentioned something about Rule 5.
But what type of effort would you put out? An easy calm ride, sure. Even with some harder efforts here and there, OK. But the OP said he has a big ride, so I assume he means it'll be a balls to the wall type hammer fest. Would you go out on that type of ride if you had a cold?I ride anyway unless I have a fever. Helps the recovery.
+1. Not to mention your body needs energy to fight off the virus. Big effort rides probably only slow recovery ime. Still hard to resist those week end rides after working all week, shuttling kids, fixing the damn pool pump again, etc...But what type of effort would you put out? An easy calm ride, sure. Even with some harder efforts here and there, OK. But the OP said he has a big ride, so I assume he means it'll be a balls to the wall type hammer fest. Would you go out on that type of ride if you had a cold?
Besides, if someone who may disease me showed up on a ride it may upset me. I wouldn't want him breathing hard, sweating, and shooting snot rockets near me.
I'd really have to be very close to fully recovered to go on something like that.
Thanks. Not a century but a tough 79 miles. Think I am doing it but just will be a little more cautious. Worked too hard for this over the winter to skip it.Depends on the length of the ride. You can probably manage to go hard for an hour or two. You might not be on the top of your game, but, you should be able to utilize Rule 5 and hang for that long. If, however, this is a century ride, I would adjust my goals and ride mostly for endurance and not go great guns. Nothing like hanging with everyone for 2 hours and then taking another 4 hours to limp in alone with nothing .... miserable .... wondering why you decided to ride with this *&#$ cold anyway ....
Standard advice is that if it's above the neck then it's OK to work out but if it's in your lungs or you have an all-over ache then rest and fluids. And even with a head cold if you go hard and burn yourself out you most often will cause the cold to worsen significantly. I've continued riding though lots of colds but that is NOT the time for hard efforts.Thanks. Not a century but a tough 79 miles. Think I am doing it but just will be a little more cautious. Worked too hard for this over the winter to skip it.
I tried that a few months ago, it helped but only for a few hours...This helped me lessen the impact of a cold.
Vitamin C. Lots of fluid, restCatching a cold two days before a big ride.
Any advice?
Want to ride.
Listen to the man. If yours is the latter kind of cold, you can do significant, and worst case even permanent damage to yourself. Even if it's just a head cold, I doubt it'll be worth it. It's just a ride. My 2 cents.Standard advice is that if it's above the neck then it's OK to work out but if it's in your lungs or you have an all-over ache then rest and fluids. And even with a head cold if you go hard and burn yourself out you most often will cause the cold to worsen significantly. I've continued riding though lots of colds but that is NOT the time for hard efforts.
