1 - 5 of 5 Posts
I replaced the pulley wheels in my D/A 7800 RD with ceramic-bearing wheels from FSA. I noticed that the original top pulley wheel had 1-2 mm of side-to-side play, while the top FSA wheel has none. Is this play important? If anything, rear shifting seems faster with the FSA wheels.
Supposedly, the lateral play in the upper jockey wheel assures clean shifts even if the derailleur adjustment is a bit off. So with perfect derailleur adjustment, a jockey wheel without lateral play could well deliver crisper shifts. Be aware that nasty internet wars have been fought over the intended purpose / effectivenes of the patented Shimano "Centeron" upper jockey lateral play feature.
· Premium Member
You probably replaced a jocket wheel with a bushing, for one with a bearing.
The top pulley on most Shimano systems has a bushing, which does allow a little bit of side-play. It helps correct for some slop in the system if the chain isn't lined up PERFECTLY with the cogs.
With a nice-day or race bike, you should be fine, but I've definitely appreciated this on my commuter... I go through maybe two of those pulleys a year.
JimP said:
The DA top jockey wheel has 2 rows of miniscule ball bearings and will move back and forth 1-2 mm.
All Shimano rear derailleur top jockey wheels have lateral play—doesn't matter if they're running on a plain bearing (often ceramic) or a ball bearing.
1 - 5 of 5 Posts
