1 - 8 of 8 Posts
I have an IF planet X with 130mm rear hub spacing. I have tried a couple of road cranks but the chainstays are so wide it is hard to get a good chainline without the cranks being too near the stays.
Anyone have any crankset recommendations or ideas? Do I need mountain bike cranks?
Any help would be greatly appreciated.
I have a SS IF as well. I am using the older Dura-ace cranks with an ultegra triple bottom bracket. Works great. I have 135 spacing. Hope this helps.
Thanks.
Can you answer a few more questions for me, please?
Are your stays crimped at all? Is that a square taper bottom bracket? Where does your chainring mount?
Stays are not crimped. The bottom bracket is the octalink spindle. The chainring mounts on the outside. I use a 42 tooth spot ring with a Phil Flip Flop hub. No problems at all with the chainline. Hope that helps.
I've got the exact same set-up on my Seven SS 'cross: Shimano D-A cranks and BB (used for triples) and Phil Wood rear flip-flop. No probs at all.
M.
Squalor
Girlie bike... :)
At least warsh the dang thing you slacker!
LP
1 - 8 of 8 Posts
