1 - 2 of 2 Posts
For those of us who love doing singletrack on the Fargo (and wonder why it works so well), I would recommend checking out Jeff Jones talking about his new Jones Plus bike design:
Jones Bikes ? Jones Plus ? This is it.
Longer chainstays, shorter reach and lower BB drop than a typical MTB geometry (plus a rigid fork). He actually has a lower BB than the Fargo's 70mm:
Jones Plus BB drop: EBB in top position – 76mm drop, EBB in bottom position – 88mm drop.
Great video with Jeff's design philosophy (while you watch him do a build):
https://www.youtube.com/watch?v=ytCndGtdZpg
This has caused me to want to try running a Jones Loop 710 bar on my Fargo (but with a 130mm stem).
Discussion Starter · #2 ·
I am 6'-4" (with a long upper/ body torso). On the XL 2015 Fargo, I run a 120mm 0 deg. stem with the Woodchipper bars; as well as a setback Thomson seatpost (and it feels really short for me). I think that the combo of the tall stack on the bike and the 60cm ETT make it feel short. I keep wishing that I can sit further back on the seat (which is as far back as it goes) when riding in the hoods on the Woodchipper).
I know that with MTB's and wide bars, the wider you hands are on the bars the shorter your stem should be; so I am hoping that when I test out the Jones loop 710 bars with a 130mm Thomson stem that allows me to have a similar ride position as Jeff Jones describes for his Jones Plus.
From Jeff's blog:"The Jones Plus 24″ has less reach than a small Surly ECR (398mm) and the 25″ has less reach then the medium (416mm)."
The Jones Plus 25" has a 415cm reach + 110mm stem = 525mm
The Salsa Fargo has a 391mm reach = 130mm stem = 521mm
ECR | Bikes | Surly Bikes
FARGO X9 | Bikes | Salsa Cycles
Jones Plus | 29+ | Complete bicycle
What stem do you run right now? Jeff would probably tell you not to run the 130mm stem unless the Fargo has a really really short top tube for you.
I tried a Jones bar in 2014 and it didn't work for me at all.. I had a 100mm or 110mm stem on the bike I tried it on. If i try it again I'm going to put something like a 50mm stem on with the Jones bar and probably move the saddle back 1cm.
1 - 2 of 2 Posts
