NEO Dan said:Hi Ean,
It's possible, I think.
I have a Large and I am at 31.125" measuring through the center of the cam bolt on the post.
I have 1cm of post left
The seat tube C-T on my frame measures ~51.5cm
So you will be up at the limit, or very close to it. But CC has the NQA returns policy so I say go for it. It's a very fun bike to ride!!!![]()
BB - Seat rail center ~30"-30.25" depending on angle and how you measure.JimmyD said:That's the one. Size large. I used the calculator at cheapcarbon frames to determine the stack and reach.
Thanks for the pic peanya. It always helps to see A visual of these things to get a rough idea of what may be possible.
Anyone k ow what the max BB-top of saddle height is on a size L SL01?
JimmyD said:Anyone k ow what the max BB-top of saddle height is on a size L SL01?
Hey - Just how tall are you; what's your inseam?JimmyD said:Thanks again for your help NEO dan. sounds like the streampost will be very close but possibly 0.25-0.5 inches too short for me...I wonder how much difference half an inch will make??
I measured mine from BB center-along the seatpost and took the measurement at the seat rails. Ill take it again to double check
The stack and reach figure i have are from the BMC web site...I wonder if frame measurements from manufacturers are like weight measurements and never quite accurate![]()
NEO Dan said:Well keep looking then because the SL01 is gonna be at least 2,380 grams for the frame, cut fork, and post.
