I recently set up a 1X on my LeMond Zurich using my existing Force crankset with a Rotor 40T QCX1 chainring mounted on the inside of the spider. I’m running a Force WiFLi RD, SRAM 11-32 10 cog cassette, Force 10 speed shifter and a SRAM 1070 chain.
This is a dream setup for me with one exception. My recollection from my old Force compact setup (with a Force med cage RD) was that when in the small cog, a single tap would NOT downshift from the 11 to the 12 but do nothing (same sorta failsafe as double tapping when on the big cog). That was good.
With the 1X setup, when on the small cog, a single tap downshifts—not a double tap. A double tap while on the small cog will shift 2 gears, up to the 13. Since I’m already giving up top speed (with the 40T chainring), I’d rather not be losing more speed by unintentionally downshifting to the 12 because I single tap if I forget that I’m already in the 11. I’m getting by looking down at the cassette—but that’s not always the smartest thing to do at speed.
All other shifts are as they should be--double tap downshifts and single tap upshifts.
I want a single tap while in the small cog to do nothing.
What am I overlooking here? Thanks.
Louie
Louie
