So I bought my son (who really loves biking) a 20" Specialized Hotrock about 2 months ago. He loves the bike except for one thing. The rear brake knocks really bad and loud when he's braking. It's easy to reproduce when the bike is on a stand though not as pronounced.
I tried making all kind of adjustments to the brake and pads but nothing helps. Finally I just broke down and took it back to the LBS where we purchased it from. They looked at it and said it's most likely because those bikes have a seem in the rim that's causing the brake to bounce when it hits the seem. They tried a few adjustments to no avail and pretty much said I'd have to live with it. I said I found that unacceptable for a $350 plus bike. I could understand if it was a $100 Walmart bike. After getting a little pushy with them they reluctantly agreed to try to swap out the rim with an after market one to see if it would help but he said it would have a seem too and probably wouldn't elminate the issue. I said well let's check the seem compared to the one on the bike to see if it was any better so they didn't waste their time if it was the same.
After comparing closely, I could feel that both sides of where the seem meet were not flush. The rear portion was slightly raised so I could see how this could cause the brake bad to get hung up. Does this seem like the likely culprit here? After inspecting the aftermarket rim, it too had a seem but it seemed flush. I had to leave the bike in order for them to do this and should be ready in a week. I commented that I expected this to resolve the issue and that the problem seemed obvious to me.
I kind of got a vibe from the LBS like they really didn't want to do this for me. Am I expecting too much? I don't see what the big deal is. Can't they just charge back the time and material to Specialized? I assume Specialized stands behind their products. They also kind of implied they've seen this before but not to that extent, yet they said they've never discussed it with Specialized. Has anyone experienced anything similar? What would you do if the issue does not get fixed?
