Joe, Will the Toupe Pro with Carbon rails, fit the Venge seat post with its side clamp mechanism?
Hey Jeff,Hi Joe,
Bit of a newbie here compared to the other guys on this thread. BTW, love reading the banter you guys have going, learned a lot. Let me 2nd the full group set idea. Bad taste from FSA cranks from my 06 Tarmac. Went through 3 BBs. DA components however solid as a rock and like new still. And seriously how much more are 105 or Ultegra brakes vs Axis or whatever they are called? And love the idea of a price with wheel set and price without wheel set on new bikes.
My question, and it is really basic, I am a big guy 6'2" x lets say 240 lbs (carbon warranty limit) at least I was at some point in jr high. I have two girls, so I have to be able to justify the spending on my bike toys. I am getting older and have a congenital narrow spinal column. As I am aging, I am having neck and shoulder pains on my Tarmac. Decided that I need to trade in for a more upright ride. And yes I have a hideously upturned stem already and run 28s. Have rode most of the plush type bikes and clearly favor the Roubaix (though I would argue that the Felt Z4 is a better bargain vs the Sport model, but not nearly as plush). I really want the Expert but my wallet says the Sport. I never change components, not a great bike mechanic. I can live with 105 vs Ultegra, I will use my custom CXP/Ult wheel set, but what is the diff in FACT 8 vs 10 that are relevant to me? The Sport weighs right at 20 lbs and the Expert a bit over 17.5 according to the scale hanging at my LBS. Stock 58s.
thanks, Jeff
Yep, this is accounted for! The new Tarmac ships with a 50mm longer seatpost than the SL4 (400mm on larger sizes and 350mm on the smaller sizes). The seat tube on the new Tarmac is about 30mm shorter than the SL4 so it should be no problem.Regarding the new Tarmac. I ride a 61cm, lots of seat post showing, but not at min insertion line. The new Tarmac eliminates some of the extra room for the minimum insertion line.
Did you guys account for this with a longer post or am I just out of luck with the new design? That would really suck since the big frames and the small ones are the ones that benefit from the new design.
Ya, it sucks. I don't understand much about IT but I guess we are doing a big server migration that is taking more time than normal maintenance ordinarily would. Sorry about the inconvenience!Joe,
what's up with that? I understand they need periodic updates, but to take it down for more than three days, that's a LOT of time.
What's up that takes so much work?
thanks much
I understand, a little color to spice things up is always nice! I'll pass your feedback on to the shoe guys, thanks!another non-sequitur, probably my own special interest group, but is there any chance of specialized using one of the shoe colors OTHER than black for wide/narrow sizes? i have wide feet, and adore specialized shoes, but i'm getting sick of only seeing black shoes in my size year after year. maybe mix it up a bit every once in a while for the wide/narrow crowd?
Great question,This might seem a little picky, but the shape of the helmet leads me to believe that there could be huge differences in its aerodynamic properties at different angles for your head as you ride.
Seems like too much chin down could even make it less aero than a standard helmet.
Do your tech guys have any tips/thoughts on getting it right? Meaning, can they give some sense of the head position, in layman's terms, for which it was designed?
Thanks much
Those shots of Froome looking at his stem are funny as crap. No doubt you guys were passing that link around the office for a hoot.Great question,
W
However, when a rider put his head down (i.e. Chris Froome Looking at Stems) he’s usually closing off airflow that would hit the chest. This is often (not always) more aero than a head up position as the rider has reduced his frontal area.
Hope that helps!
It seems like wheels are the bane of all bikes except for the very top-end offerings in order for the manufacturer to save money. I just recently purchased a Roubaix Expert which has the Fulcrum S4 wheels. I love the bike and the back wheel is fine but the front wheel has an annoying thud at every revolution while braking which is apparently due to a poorly finished weld on the rim. I think it's embarrassing that Specialized would use such a poor product on a $3800 bike.My wife and I own 8 Specialized bikes. I have been happy, even delighted, with most all of them but for two things: My 2010 Specialized Roubaix Expert EL wheelset which basically thrown in the trash because of so many problems. And then my 2009 Specialized Epic brain repeated failure. I thought both should have been warranty covered but that wasn't the case. Specialized would have come out ahead if they would have warrantied those issues because I would have bought far more expensive bikes than the ones I have today as I have methodically upgraded. But having to shell out thousands of dollars to other vendors to solve the problem was bad for both Specialized and my wife and I.
I was riding with a friend who had bought an old stock close out - the same 2010 Roubaix I have - and I kidded him being completely silly and not serious by saying, "There's not a snowball's chance in hell you'll finish this ride on those wheels."It seems like wheels are the bane of all bikes except for the very top-end offerings in order for the manufacturer to save money. I just recently purchased a Roubaix Expert which has the Fulcrum S4 wheels. I love the bike and the back wheel is fine but the front wheel has an annoying thud at every revolution while braking which is apparently due to a poorly finished weld on the rim. I think it's embarrassing that Specialized would use such a poor product on a $3800 bike.
Yes, the Praxis Conversion BB fits on the Tarmac. You just need to push out the stock bearings and clips first. The Praxis BB goes in easy after that!
If they look like the picture below then yes they are for Shimano cranks. I went through two sets in 5k miles due to creaking. I would recommend using something like this:But the press in adapters that come with the frame and BB, are those for shimano conversion? That would be great if they were...
