1 - 2 of 2 Posts
1 Pair of used Roval CL 50 Disc Wheelset + Zipp Double Wheel bag. 5K miles on the wheels
Comes with Dura Ace Rotors 160\140mm Tires are setup tubeless Conti TL5000 28mm which have some life left in them
Newer DT Swiss 11 Speed Freehub body and bearings cleaned and DT grease applied in the last 1000 miles. There is some pitting on it but a cassette will easily mount and dismount without catching.
Every 6 months Gyeon Matte and Cure have been applied to the wheels.
Used for 2 years but not in winter. I am 200 lbs and these never had to be trued or have a spoke come loose.
No major cuts, scratches or dents.
The front rotor is slightly warped but both only have about 1000 miles on them.
No cassette
If you do not need the Rotors, Tires or Wheel bag we can adjust the price.
Rim Type: Carbon clincher, 2Bliss-Ready
Rim Material: Carbon
Braking Surface: Disc brake only
Rim Depth: 50mm
Rim Width: 20.7mm internal, 29.4mm external
Front Spoke Pattern: Two-cross/Radial (2:1)
Rear Spoke Pattern: One-cross/Two-cross (2:1)
Spoke Count: 21 front, 24 rear
Spoke Type: DT Swiss Competition Race T-head
Nipple Type: DT Swiss Pro LockBrass hexagonal
Front Hub: Roval AFD1, Centerlock, sealed cartridge bearings, quick-release or 12mm thru-axle end cap
Rear Hub: Roval AFD2, Centerlock, sealed cartridge bearings, DT Swiss 350 internals, 11-speed, quick-release or 142x12mm thru-axle end cap
Assembly Method: Hand-built
Extras: Roval steel quick-releases, Roval tubeless plugs and valves, Front quick-release & 12mm endcaps, Rear quick-release & 142x12 thru-axle endcaps
Total Wheelset Weight: 1,515g
1 - 2 of 2 Posts
