Very funnybut it does have a fork that could shear off at any minute......
Are you running clinchers? Usually the sub 14lb bikes are running tubulars saving about a pound.My Red Keyline SW SL4 is set up very similar to yours, but it is weighing in right at 15 pounds with pedals and cages installed. Is mine weighing in more than yours since it is a 56cm? (I understand that you haven't installed pedals or cages at this point)
Yes. I am running Zipp's 404 FC Carbon Clinchers (beyond black).Are you running clinchers? Usually the sub 14lb bikes are running tubulars saving about a pound.
I am running Zipp's 404 Tubular (beyond black) lighter and cheaper.Yes. I am running Zipp's 404 FC Carbon Clinchers (beyond black).
You have heavier sadle, seatpost, wheels, stem, pedals, bottle cages and i don't know and handlebar. You want anything more? By the way, i like your stem(ZIPP SL145?). I want your opinion. Thanks.Mine's over 14 pounds, 14lbs 13 oz....6.73kg.
Look Keo Blade pedals, 303 FC CC, ordinary plastic cages, size 56.
I was kinda kidding....this build came in under 15 lbs, its just a smidgen heavier than my EVO. I was pretty surprised.You have heavier sadle, seatpost, wheels, stem, pedals, bottle cages and i don't know and handlebar. You want anything more? By the way, i like your stem(ZIPP SL145?). I want your opinion. Thanks.
Off subject, but what do you think of those pedals? I'm using Keo 2 max for reference.I am using X-Pedo Thrust 8 pedals and S-WORKS Chicane saddle. The frame is 56.
