1 - 2 of 2 Posts
I am getting a KG381 to replace my current bike that uses a clamp-on front derailleur. So I need to get a new one for the KG381. I have been using a regular Record FD with the SLK 50/40 compact crankset and it shifts pretty smoothly.
Since it is braze-on and does have too much space to play with along the seat tube, do I need a compact FD?
Slowpoke
I would suggest getting a compact-specific braze-on FD. It will probably ride high because you can only go so low with the braz-on setup. The extra length in the guide is helpful in that circumstance.
The FSA C-16 FD is cheap and really good. The IRD is exactly the same component, so you may want to look for one of these as well.
1 - 2 of 2 Posts
