1 - 7 of 7 Posts
I have been using a technique to increase durability of my Speedplay cleats by using using some 3M non-slip tape that is cut into pieces to cover both pair of screw holes and add a half circle piece to front of shoe toe area. This protect screw heads, prevents cleat wear and provides traction when walking. I can also insert Coffee Caps over cleats for additional protection.
See pics for material used and application.
good idea...
Seems like a reasonable idea.
What's the piece of tape around the spring wire on the left side? Is the wire gouging the pedal spindle? I had this problem with my left foot only. It indicates the need for a wedge to correct foot misalignment.
The tape is a piece of teflon tape I put on both left/right cleats due to some wear interface with pedal axle. I not sure about the wedge shim. It is happening on both sides. These are older Sidi Energy shoes and the cleats have about 2-3yr use. I think it's time for new cleats.
just what I figured...
Thought that looked like teflon tape.
Cleats may not last more than 3-5,000 miles, maybe more depending on maintenance. If you still get cleat to pedal spindle contact with new cleats, try the shims. A foot misalignment problem is quite common.
I've owned several sets of new pedals and cleats. I always got the same rubbing on the left side. Only a wedge would cure my problem.
Juanmoretime
Those cleats are shot. Look at how flat the locking spring is. I wouldn't be much fun having that snap. I replace mine way before they get that worn.
Juanmoretime
biker said:
Can the springs be ordered seperately ? If so, what is the cost ?
They can be and are much cheaper than the whole cleat. Call Speedplay or check with your LBS since they can order them for you. I remember they had a new spring kit but don't remember the exact cost. TMB (Too many birthdays!)
1 - 7 of 7 Posts
