1 - 7 of 7 Posts
So my left pedal has a noticeable up/down "play" around the spindle. I can feel and hear an audible "click" on every upstroke. Thinking it was the cleats, I got new cleats and the problem persists. Not sure it's the bearing or something else, but was just going to buy new pedals, but wanted to ask first.
a real member's member
google images shows you can replace the bearings, so you can obviously tighten the whole unit as well.
Can't see anyway to get pedal free of spindle. I removed screw at the dust cap but my pedals don't separate in half like the video.
Iron Circle Electrical supply Wire Finger Grey Composite material Thumb
Sent from my XT1254 using Tapatalk
Remove the dust cap with a utility knife tip by prying it out. Inside you will see a nut that you remove and then the pedal comes apart.
1 - 7 of 7 Posts
