There's no particular reason to remove the frisbee, except that folks think it looks lame. There's not a ton of reason to have it on either--the theory is that it keeps you from shifting your chain off the inside into the spokes, but IMO it doesn't even really do that, since your derailler will be in the spokes before the chain comes off. A poorly adjusted derailler isn't any safer with the frisbee in place.cgilker said:I've removed the reflectors, but why the spoke protector?
Something sharp....last time I did mine it was a combo of a razor and a wire cutter tool.Jack1576 said:Is there a way to take it off without removing the cassette?
Trying to avoid the newbie label...
No, no. All that extra weight is so close to the hub that the rotational inertia is not as big a factor as simple inertia. It wouldn't be good for more than 1 mph, and that only on rides more than 19.847 kilometers with no less than 43.7 meters of climbing (assuming an equal amount of descending).Zaurusman said:Besides ... didn't you know that extra 30 grams of rotating mass is worth 2 mph average?![]()
Are you able to tell us another independent entity that has performed rigorous scientific triple-blind spoke protector testing and made the results available to the public? Somehow I think not!All that extra weight is so close to the hub that the rotational inertia is not as big a factor as simple inertia. It wouldn't be good for more than 1 mph, and that only on rides more than 19.847 kilometers with no less than 43.7 meters of climbing (assuming an equal amount of descending).
Chris Oz said:You slightly off track about the partial disc wheel idea, they actually put them on to decrease the fan effect from the rear cassette (they partially block the end off) I don't have the link but apparently once you have shaved your eye browse off it should add at least 5 kmph to your average speed. The other option if you don't want to look like a beginner is to fill you cassette with foam (I hear it is what all the pros do).
