1 - 4 of 4 Posts
Okay builders, I weigh 195# +/- and have a rear Powertap hub laced with 32 spokes into a CXP22 rim w/ 3x pattern. As I am tuning up the wheel, what tension should I be looking for for drive side and non drive side? (I will be checking with a Park Tool tension meter, which I know is dubious, but at least I should be able to get the tension consistent around the wheel)
TIA
A wheelist
The non drive side tension will be what it has to be to allow the correct dish. Try plucking spokes for relative tensions.
'brifter' is f'ing stupid
using the chart that came w/ your tension meter, look for 100kg w/ whatever gauge/type spokes you're using. don't worry about the non-drive side, as the previous poster said...it will be what it will be. get 100kg on the drive side and keep everything even and you'll be good.
I would guess 110-120 KGF on the drive side, but maybe Mavic has their own recommendations. Make sure the spokes are going in as straight of a line as possible. 3x with a PowerTap makes it easy for the spokes to have a bend at the nipple.
I just checked, and Mavic recommends 70-90KGF on the rear drive-side. That is much lower that what most rims can handle, but that is what they say.
"Respect the appropriate spoke tensions; Mavic recommends spoke tensions between 70 and 90 kg (for a front or rear wheel on the free wheel side with a
crossed 3 pattern). Inappropriate spoke tension can generate too much stress and damage the rim;"
1 - 4 of 4 Posts
