So, I picked up the Delta CX when Airborne had them marked down a little while ago. It did fine commuting on paved roads/mild offroad. Yesterday I did one of our spring races up here in Canada, and found a huge issue with the Apex (and the Rival and Force seem to be the same/similar design). The cable, after exiting the housing from the seatstay to the derailleur is routed through a groove on the bottom of the RD before it gets locked down with the bolt.
2 minutes into the race, I bunnyhopped a pothole, and the bounce on landing caused the RD to pivot, allowing the cable to come out of the groove and preventing fully functional shifting. It happened again towards the end of the race after hitting some rough ground. If you're in a high gear (11 or 12 tooth ring on the cassette), the RD can actually move over and jam the chain between the cassette and frame (probably because I had my limit screw backed out, as the cable was preventing it from moving too far down during normal operation).
It's an easy field fix without tools, but not something you want, or should ever have to deal with in a race. Anyone else encounter it? Do the next level up have an improved design (eg deeper groove?) to prevent the cable from popping out? The Rival looks like it's pretty much the same, but it's a little hard to tell from the manufacturer photos.
