1 - 20 of 37 Posts
I am having issues with the front shifter on my force group set
was heading off at the lights just getting into my rythm when i went to go up to the big ring.
So push the lever over and i get these big clunk clunk so try again and again and again for the same reslult and still on the small ring
about a mile down the road i finally get it to move to the big ring and from then on it was fine crisp and clean shifts
Any one out there had sinlilar issues ???
I think the lbs wants to send it back! I hope they replace it or atleast give me a temporary one to ride with
Twiggy
avalnch33 said:
cable stretch?
poor adjustment done by the person that built it?
could be a couple things.
I have had them adjusted and serviced twice already and it still keeps popping up
I have asked the bike shop to chat to the rep and I will be dropping the bike off at the shop so he can have a look at it.
Will report back with the resutls next week.
Twiggy
OK just heard from the LBS
They had the rep in from sram to look at my shifter
With in 5 min he said take it off and it will be replaced under warranty!!!
LBS manager said it was a bit suspicious that he came to the conclusion af a straight replacement of the lever and he along with me suspect a quality issue with a batch of levers.
He said he has never seen the rep agree so quick to a warrenty issue before, so it is a strong indication they are having issues. It may be confined to Australia i dont know ???
Any one else out there having issuses with their 2010 sram froce front shifter ????
Twiggy
AKA Old Man
I did for a while,, it was very hard to dial in.. My last adjustment tightened a loose screw and all was well...
Works great now..
Getting my Rival/Force (crank) front derailleur adjusted and working hasn't been smooth. LBS mechanic is good, but admits not much experience with SRAM. It's possible I've had this happen, not see it repeated and then think it must be me that's confused. I repeatedly find the front derailleur in a different position than I thought it was, but chalk it up to my mistake. I've had more trouble with the chain dropping on the inside, but hey, if it can happen to Andy Schleck, I can't feel too bad.
I'm having issues with mine Force FD shifting too, It has been adjusted twice by my LSB, but still getting stuck in the small ring. Sometimes, it works fine, and sometimes it doesn't. Is it true that some of those Force FD are defective and how you can determine that's what it is. Any feedback is appreciated.
Discussion Starter · #10 ·
Hi
I had mine adjusted a few times but it still didnt work sram replaced it no questions asked the new one is perfect and much more responsive get it looked at and refer to this thread aswell as i think this is the real issue for the lever issue
http://forums.roadbikereview.com/showthread.php?t=226007
Good Luck
Twiggy
I had both of my shifters do something similiar about a year ago. Neither would shift, though the lever would move. I sprayed some lube into the shifters and haven't had an issue since.
Steve
i don't think it's a problem with the shifter or the fd. it's more likely a problem with installation. the cable needs to pass OUTSIDE the tab (to the left when viewed from the rear of the bike) on the derailleur, then over the top of the cable bolt in the groove. this increases the lever arm and allows a little more movement over the top of the big ring. try it...i think you'll find the feel at the lever much more comparable to campy/shimano when the cable is installed as intended. good luck.
makes me wonder about the quality of mechanics at some lbs's. it must be a manufacturers defect if we can't get it to work...lol.
i don't think it's a problem with the shifter or the fd. it's more likely a problem with installation. the cable needs to pass OUTSIDE the tab (to the left when viewed from the rear of the bike) on the derailleur, then over the top of the cable bolt in the groove. this increases the lever arm and allows a little more movement over the top of the big ring. try it...i think you'll find the feel at the lever much more comparable to campy/sram when the cable is installed as intended. good luck.
You wouldn't be able to post a photo of that would you? I'm having similar problems with the shifting on my 2011 Force FD too.
Thanks,
I'll try once I get home.
Oh, thanks... I took a look and there is like a little cam that the cable goes over before it clamps in. Mine is correct like you have described, I guess I'll have to play around some more with the adjustments.
This is the first SRAM bike I've owned and so far the FD shifting is the only thing I don't like otherwise it seems very nice...
Using left shifter correctly with Force?
Just wanted to confirm that I am using the left shifter correctly....(using Force)
This past weekend was the first time I actually made use of the left shifter while cycling. Had trouble shifting in both directions, either nothing happens after a click or a loud crack sound before a shift (wasn't consistent like the right shifter)
When I got home and after a few minutes trying to figure out how to get the front derailleur to shift, I got it to work consistently by doing the following:
To shift to the small chainring:
-tap twice (one click sound for each tap, nothing happens on the first click)
To shift to the large chainring:
-one long tap (heard one click, could have been 2 small clicks but couldn't tell)
Is the above steps correct or could there be something wrong with the left shifter?
Curious because the click sounds are nothing like the right shifter which is what I expect.
thx
You're doing it right.
The first click does do something -- it's the "trim" position for the front derailleur while on the big ring. It moves the derailleur a little bit closer to the frame (but not enough to move the chain to the small ring), which allows you to use your larger rear cogs without the chain rubbing on the derailleur.
Yup.
Sounds about right to me. The left and right shifting don't really feel or sound the same.
Asad
I have had very spotty front shifting with a Force FD & Red shifters. I have had choppy upshifts & more drops when upshifting than I can count. My Force crankarm looks as if a dig has been chewing on it. Several mechanics at my LBS have adjusted it, and the problem is still there. SRAM is replacing the FD.
The cages on SRAM Force & Red FD's are flimsy & deform easily.
1 - 20 of 37 Posts
