1 - 10 of 10 Posts
Moderatus Puisne
Red...
Well, the "full retail" usually had the ceramic BB included, which costs a bunch. People finally started separating them.
$260 is still really dang cheap if you can find one that's not, like, a 177.5mm 34/50.
The 2009's with the Ceramic BB come in around $550. Less the BB cost, the crank is still $350 or so. That's why I'm still amazed at these things going for $260-$280.
Maybe there was a run with mild blemishes or something.
teh moreon said:
will the red crankswork with rival cups?
Aren't the Rival and Force BBs the same (standard non-ceramic)? In any case, unless it's one of the new BB30 Red cranksets, yes they will work.
Discussion Starter · #8 ·
Yes-it's the same thing just without ceramic bearings.
Supposedly SRAM recommends pretty meticulous maintenance intervals for their ceramic bearing BB. I have the rear derailleur (with ceramic bearings)--and they state that the pulleys should be lubed every 200 hours or after ANY exposure to water!
That has me a bit leery about ceramic bearings as a whole.
Maybe I've been negligent but with Shimano 9-speed, I NEVER check the pulleys or the BB...
Carbon Fiber = Explode!
Remember, GXP is a standard.
The GXP BB is the same for all SRAM, Truvativ, Bontrager, etc... cranks.
The GXP "team" is 30 bucks. Everything else is ceramic and at least $100+
1 - 10 of 10 Posts
