while you can use a standard tire with a ust rim and stan's juice, some work better than others. i think if you go to stan's website they list which tires work best.
other than that if your tire is seated you need to lay the wheel on its side and work the juice around the bead completely[both sides]. the juice will leak out untill it forms a seal. then you should be set.
