1 - 20 of 21 Posts
Took a fall last week that seems to have jammed or broke something in my right Dura-Ace STI shifter. I can't get it to move up or down. There was not much visible damage except for a few scratches. Are these things rebuildable or am I looking at a new one?
Adorable Furry Hombre
Methinks you're SOL--unless the "STI overhaul in a can" (i.e. WD40) can fixit
Yeah good luck
I know of few people that are able to take apart an STI and successfully put it back together. Maybe a Swiss watchmaker with a good microscope. I myself have disassembled and broken Ultegra shifter with no luck in getting it back together. With no manual and no replacement parts available (unless you have another bummed shifter to robs parts from), Shimano leaves you little option other than to buy a whole new one. That's live with Shimano.
Sol!!!
I can't imagine it's a wd-40 fix. The thing is less than 3 months old. I've heard they are very complicated gadgets and not to be tackled by the faint of heart, but what have I got to loose?
Go for it then
You might have more fine motor control than I have. I kind of jumped into disassembling it before carefully noting how everything fit together and pretty soon I had tiny springs and ratchets lying all over the place. If you need parts, you might have a hard time tracking them down. Unless your LBS has a dead shifter laying around that you could use as a donor, there isn't much else that can be done. There's also little if any cross-compatibility between different levels of shifters, so you'll most likely need another bummed DA shifter to get parts from. Don't mean to be pessimistic, just want you to know what you might be getting in to! :)
I used this exmaple when my buddy was giving me crap about selling my DA for Record. It is NOT rebuildable. You can buy some basic repair parts but opening an STI basically means "BOING!" as the internals fly across the room.
K
STI is a great example of the disposable society we live in. I hope you have an arm and leg to spare for a new set. Your first newborn or left nut will also suffice.
Rowing a similar boat
I've got ultegra 9 speed shifters from around 2000. The right shifter is beginning to free swing without shifting (shifting big lever to easier gear). The bike is going up for sale as my new team will have team bikes this year.
Any ideas of how this may be fixed, or the more likely or should I say, appropriate question, anybody got a working right 9 speed ultergra shifter for sale?
I agree it would be nice to have the item rebuildable, but it is 6 years old so I really can't complain. I just don't want to sell the bike to someone and then they need to replace it immediately.
thanks
Larry Lackapants
Wd40?
thanks
Hello,
This could be actually a wd40 fix. I've met a similar problem with some old 7 speed mtb shifters, where the lubricant was old and had gotten sticky into such an extent, that the blocking pads that normally slide into the notches of the ratcheting mechanism to keep the shifter into gear, were almost stuck. The on/off movement of the blocking pads is controlled by small springs that are not strong enough to move the pads if they're full of sticky grease + dirt.
I guess modern STI's are a bit more complicated than 7 spd STI, but a "sticky lubricant" case could be solved by wd40 applied - generously -
on the mechanism. That is, if you have enough access to the mechanism to spray wd40 on.
I hope my explanation is not too tangled up...
Good luck
brblue said:
Hello,
Good luck
Thanks for the advise, I'll give it a try as soon as I get out of the salt mine today!
Ken
Springscylist
This might fix it.
thanks
There is a small philips screw on underside of the brake lever at the top. This is best seen with the bike upside down. Tightening this may solve your problem.
Squirrel Hunter
Cables?
Check your cables. Could the cable head have become dislodged or something twisted where the housing enters and just binding? Wishful thinking but something to look at before breaking out the credit card.
Resident Dutchbag
Hope this helps...
Bike Dude
Do you have to have STI ?
I would loosen and then remove the shift cable, flush the hell out of the shifter with WD-40 then use a good lube and try to cycle your shifter repeatedly. If this doesn't work you might switch over to Dura Ace bar end shifters. They last a real long time. A new set of STIs are going to be real expensive.
NeoRetroGrouch
Warrantee. Send it in. You will have a new one in 4-5 days. - TF
Thanks
I'll give them a good cleaning... I am planning on selling the bike as soon as my new race bike comes in. I don't necessarily need STI, but I would prefer them, and if I'm going to try to sell the bike, I think the STI shifters would be more appealing to the next buyer than bar end shifters.
I could be wrong, but I'm trying to market the bike the best way possible.
thanks,
Ken
This may be the ticket to ride!
Just got back from the gym and blasted WD-40 thru the shifter. After letting it drain, I put a shot of teflon lube into the shifter. On the stand it seems to shift fine. I'll give it a try tomorrow and let you guys know how it goes.
Many thanks for the help. Hopefully when I sell the bike in a month or so, the next owner will be just as thankful for your help.
Ken
THe same thing happened to me and lbs said no...
I would have to get a new shifter.
Check the grease in the shifters...
brblue said:
Hello,
Good luck
Something like that happened to me and the shop told me that grease and lube get old and need to be replaced.
1 - 20 of 21 Posts
