1 - 2 of 2 Posts
:confused: I was looking for some help in identifying the cause of a chirping sound coming from my front tire. It happens when I hit bumps in the road. It seems like it's a pinching or binding of some type but not sure. If anyone could help it would be appreciated. Also, how do I fix it? Thanks
Matt
· Rollin' Stones
Chirping?
I'd check your quick releases first. Make sure they are tight. See if the axle is in the dropout correctly too. If it's only happening when you hit something it may be a simple fix.It could also be the front brake contact area. Take close look at the distance from the rim to the brake pad. Start there anyways. Best of luck! Now ROCK! :23:
1 - 2 of 2 Posts
