Umm, allen bolts have the flats on the INSIDE surface of the head. Can't file the flats. Also, if it were a conventional bolt, I'd think filing would be out anyway, since it's down in the crank.QUOTE]
What are we going to do with you?
For clarification;........You Can file the flats on the inside hex of the allen bolt, and "no" we're not talking about a conventional eight-sided bolt. The point of my post was to try and restore the sharp consentric angles of the allen head. After all, it is rounded, correct??
No matter what size allen key you stick into it, you're still faced with a rounded allen head, right?
Not trying to be mean or anything, but the allen bolt has to be restored as best as you can get it, or you will have to drill it and back it out with a screw extractor. Use a small file with a squared end, and file the flats square. It does'nt make any difference what size it turns out to be, just get it square. You can always file the next size up allen key to fit, and then you'll be good to go.
