Suggest checking out the new wider HED Ardennes + C2 rims with tubeless specif profile.
Any idea how much that rim weighs? At 25mm wide, I'd imagine it's approaching the 500g range? Just curious.
I see the "tubeless specific" term thrown around a lot. It's sort of humorous to me. There's a million road rims out there, many of which are differentiated by the most miniscule amount, but recently I've noticed that more and more are being labeled as "tubeless specific".
Although 130mm road disc does technically exist, its employment is probably less than a millionth of a percent, outside of CX. Thus, all remaining road rims have a CNC sidewall, which lends itself to this vertical parallel sidewall shape. The tubeless specific term then applies to the fact that road rims are now being poached from the hybrid/comfort OE "wide" rim catalog now? Perhaps the term applies specifically to the rim's center bridge? Maybe the shape? The idea that the center is perfectly perpendicular to the sidewall a little longer than "most" other road rims, a distance of perhaps a whole mm?
It's not a bad idea to shape the rim's design if it helps with tape installation. That's what Stan's is about. But I've taped a bunch of different MTB 26"-29er rims, and haven't had any issues, in terms of tape. (Now with tire fit/seal that's another story.)
Regarding the top of the beadhook, etc., Stan's for example, is dedicated completely to designing their rim's shape and dimensions for tubeless applications, even if it meant moving away from industry (ISO) accepted dimensions. I think that with MTB disc rims, they really were able to move away from ISO dimensions, and were free to really come up with their own stuff. But with a CNC sidewall, I think that there's less flexibility in terms of design options. You have to address higher PSI, brake clamping force, brake wear, etc.
I'm not negative on road tubeless, if it evolves the sport, I think that's great. My main point is that I think the term "tubeless specific" is quickly becoming a marketing buzz term for road, (that's fine). But it seems like at this point, the primary attribute of "tubeless specific", (other than with Stan's, who does a great job at actually innovating), is simply rim width.
If you're not worried about rim weight, (which would be obvious if you're using a 500g rim), I'd recommend grabbing any hybrid/comfort 700c rim and tape it, run wider 25 - 30 tires at lower PSIs, and see if you like it before buying into a wheel system.
Zen mentioned the Archtype, I see that rim being discussed a lot. Velocity has the A23, that's a great rim. There's literally tons of great options. And, at the end of the day, if you want to spend about 1K on your wheels, then by all means, the HED C2 wheels would be right in the mix.
