1 - 4 of 4 Posts
Is there any conventional wisdom as to the strongest crank set available? I assume stiffness is correlated - and need that too if I can keep the crank in once piece.
Today I did what I thought was impossible. I was sprinting out of the sadlde up a short, moderate grade... working hard to power over it. Wasn't looking at my powermeter but typically on a thing like that I'd put out 1000-1100 watts. Well, I pushed down on my right leg and my drive side crank arm split open on the outside of the arm - bending it inward and ending my ride in a big hurry. Happened in "slow motion" - not a catastrophic failure. This is lucky - I could have been hurt. I felt the arm bend on the downstroke. And even with a big gash in the side I can't budge it with my hands. But, what the heck!? I bent/broke my crank arm! Does this happen to other people?
This was a Shimano Dura-Ace, 7800 (latest), crank, 175mm. 1 year and 8000ish miles old. My understanding is DA is some of the strongest/stiffest stuff out there.
Now I have done weird things to equiptment before.. I am not a normal sized rider. I'm 6'3", 250 lbs, and athletic. Obviusly more linebacker then cylclist - a fact which gravity reminds me of on long climbs. I've been training like a madman to cycle in the French Alps this summer and have continued to get stronger and stronger on the bike - able to ride out of the saddle longer and with greater comfort...say... to power over inclines :) Not coincidentally, I am certainly stressing my equiptment more then I ever have before... I fear more breakages as I will continue to get stronger (and maybe a little lighter but not much lower then 240... at least without amputation - I'm bizzarely heavy for my appearance... whatever.).
So... advice? Is there a gold standard for crank arm strenght? I thought DA was it. Sigh... Have already learned about handbuilt wheels - Mavic K's do ok but the rears need truing. Ride a Ti Seven built for my weight. Replace chains more often, yada yada.
Thanks for any advice.
-NW
Resident Curmudgeon
That's the 1st time I've ever heard of bending or breaking a crank arm. I folded a chainring over during an uphill sprint once, but the crank was all right. Dura Ace is some of the best stuff you can buy, as is Campy Record or Chorus.
Big is relative
I broke a 7400 DA crank at the pedal hole once. Back then I was a pedal smacker on crit corners so I probably damaged it before it broke. Other than that, a bent ring and a broken look pedal are the worst of my breakage for components. I did break four Raleigh 753 Technium frames, three at the bb, one at the seat cluster.
1 - 4 of 4 Posts
