I really like my pulsions activ-ti link but I understand that it may be fragile and the earlier models with the tight weave carbon layup were prone to breakage at the pedal-crank interface. on mine, which was the more durable wide carbon-weave layup made in the subsequent years after the initial run, the instructions stated clearly that pedal spacers should not be used and that the minimum pedal spindle measurement should be observed.
thomas voeckler rode on a strong pulsion activ-ti. my set with bb weight included is 630 grams with bolts. that's over 200 grams lighter than dura ace.
it's a delicate crankset and while it is incredibly stiff, i worry that the structure is brittle overall due to the stiffness/weight perceived ratio. it's a tradeoff you'll want to consider...
