1 - 9 of 9 Posts
I started hearing this clicking noise coming from my fork area and it started to drive me crazy. I listened to my front hub, but it wasn't there. I thought it might be the brake rubbing, but nope, good clearance and a perfectly true wheel. Turns out, everytime the magnet passes the sensor on the fork for the computer, it makes a click. This did not happen on my old cateye I had on my MTB (which is no more thanks to the hot Phoenix sun).
So whats the deal? Is this normal? Do I have a dud? If it is normal, this computer is going the way of the dinosaurs and I will get a GPS system instead. I mean seriously, that click seems to just amplify through my frame.
You're Not the Boss of Me
This may sound too stupid to be the issue... are you sure that the magnet and sensor aren't making contact? It can definitely happen, especially after a bike has been transported.
Do you have a wireless Cateye? I do and mine clicks but not enough to bother me. I have to try and hear it to know its doing it.
eminence grease
It's called a reed switch and it's what sends the signal to the computer. Wireless computers use them, not sure if wired do or not.
Every wireless computer I have (Cateye, Sigma, Vetta, VDO) does it to one extent or another.
limit screwed
My Cateye Astrale 8 (wired) uses the sensor system that TerryB describes; although it isn't loud enough that I've ever heard it while riding. Of course, my sensors are on my rear wheel and crankarm; it's unlikely I'd be able to hear them, but if your's are on your fork, it could be a different matter.
Thanks for the information. I guess I will just have to live with it for now. I guess I never heard it on the MTB because the knobbies make too much noise. This roadbike is so quiet and smooth (relative to the MTB) that any little thing I hear immediately. Its definitely a new experience for me.
Its ok
I have the same noise, from my polar sensor.
Friend of mine told my to spray the sensor with anti electronic spray, as they use in electronic factory & noise goes away.
I try & its work.
Who needs a map?
mine does it too. nothing to worry about. i can only hear it when i'm off the bike (like when i'm working on it) - have yet to hear it while riding.
1 - 9 of 9 Posts
