Get the lollipop peddles they should be lighter the the keos.
Nice tip. Not sure why that didn't come to mindparity said:Remove your rim tape and replace them with veloplugs if they fit. You can save 10 to 15 grams per wheel. Switch to a lighter tire. According to the specialized web site your tires are 220 grams. Michelin pro race 3 come in at 205 grams (on my scale). So that's 15 grams per wheel. So combine this with the other weight savings suggested by everyone else and you should be close to your target weight.
This is what I would do/ am doing.masfish1967 said:if you are not in a hurry, then replace each part with a lighter part over time. It will seem less expensive but it ain't.
Sweet bike! But as I stated in the orginal post, I wanted to drop weight without having to change out the wheelset at this point in time. I realize that that is probably the fastest way to drop some noticeable weight....but I actually really like my Roval Rapide SL45 at the moment, and not looking to drop that much $ on the 303s or any other carbon/tubular wheelset.Cado said:Here's a few idea based on my build:
The items in bold would be significantly lighter than your existing components (you can look up the differences on the web):
Specialized Tarmac S-Works SL3 Cancellara Frameset
SRAM Red
SRAM Force (callipers and front derailleur),
Zipp 303 Wheels,
S-Works crankset (BB30 only),
Stronglight CT2 53/39 chainrings,
Toupé Ti seat,
USE Carbon Alien seatpost,
FSA OS-99 stem,
3T Ergonova Team handlebar,
Dura Ace chain,
Dura Ace cassette
Speedplay Ti pedals
S-Works bottle cages
13.9 pds ready to roll now with speed/cadence sensors and magnets.
The best place to start is the wheels and tires by going tubular, but that gets expensive really quickly.
If you stick to clinchers, you can try Schwalbe Ultremo R.1 tires at 180gr each with Maxxis Ultra Light tubes at 60gr each. I use that combo on my training wheels (Easton EA 90 SLX). That would get you some good weight reductions.
for now change to the sram red (1091R) chain + red/force cassette, then i'd go with Red brakes or some other ultralight brakeset.Cni2i said:Hi everyone. Since this IS the weight weenie forum, I'm going to ask....
My current bike is at 15.30 lbs with the following main components:
1. 2010 Sworks Tarmac 52 cm frame set (with s works seat stem and fork)
2. Roval Rapide SL 45 wheel set with specialized Mondo Pro II tires and "superlight" turbo tubes
3. Specialized toupe saddle with ti rails
4. Red shifters, RD, and compact crank
5. Force brakes and FD
6. Specialized Sworks carbon bars
7. Ritchey carbon stem
8. LOOK Keo 2 Max pedals
9. 6700 Ultegra cassette (11-28)
10. 2 Forte carbon cages
11. Sram PC 1070 chain
BESIDES getting a new set of wheels, what is the best way for me to get below 15lbs? Suggestions? Thanks.
Cool link. :thumbsup: Man those ZERO GRAVITY 0G Ti ROAD BRAKE SET are sweet looking and so damn light! I felt like a little kid in a toy shop therewgeorge111 said:Here is some lite weight stuff
http://www.stealthcycling.com/c=IJXKZUQU0D5lNU7FpXVqfqAf2/category/lite_weight_parts/
The SL 45's come with titanium skewers. (at least mine did)Cni2i said:Thanks for the good tips! I would consider the red cassette but heard that it is too "loud". WhT about the dura ace cassette? Would that get me below 15? I like the Thompson seat post idea too. Are the titanium skewers easy to install?
They do. I realized that after reading the suggestions. Thanks for looking out though.fleetseat said:The SL 45's come with titanium skewers. (at least mine did)
azbiker said:If you care.....this is my sub 15lb Tarmac build....
09 S-Works Tarmac SL2 frame/fork (56cm)
Dura Ace 7900 fr+rr derailluers, shifter/brake levers, 11/25 cassette, pedals
Zero Gravity GSL Brakes
S-Works BB30 Carbon Cranks (aluminum spider and rings with non ceramic bearings)
S-Works stem (100mm)
S-Works Carbon seatpost (27.2x350mm)
Fizik Aliante Saddle with Kium Rails
Pro Vibe Bar (42cm) with S Wrap cork
Dura Ace cables and housing
King Ti Bottle Cages (aluminum bolts)
KMC X10sl chain
Wheelset is Alchemy ELF/ORC, Stans Alpha 340s, Sapim CX rays, Salsa Ti Skewers
Continental Gatorskins (700x23) with cheapo tubes
Bike with all parts listed above weighs in at 14lbs 13oz with my Garmin 305 and cadence sensor mounted.
If those Rovals are really 1600g and you want a more or less "normal" looking wheelset, consider DT Swiss Mon Chasseral, @ 1450g.Cni2i said:I hear ya. I love the way the Roval Rapide SL45 looks with my bike. But besides the looks, they also perform great on long flats....better than my EA90 SLX IMO. But I agree, they are definitely not the lightest wheels. I am probably in the minority here, but I just don't like the really deep dish tubular wheels out there.
