So I built up a single speed using a Surly "Singleator" for chain tension. How big a P.I.A. will that make it to change to a different size cog?
Assuming I break the chain long enough to accomodate the largest cog I expect to use, will it be too loose when I run a cog two or three teeth smaller? What gear range do you need for racing?
Now that it's built I'm wondering... do I need to keep different lengths of chain around?
