I went the other way for my needs, and had to swap parts out. You can adjust into a smaller <32 cassette, but you can't adjust from non-wifli into >28, you have swap parts. It was an adventure, and the principles all work to help you out.
-cassette-install what you like, matching brand probably a good idea.
-chain, between a 32 and 28, one link to long, but not significant, derailleur can handle it, or just remove a link - ez. If you have some fair mileage, wouldn't be a bad time to put a fresh chain on.
-derailleur- the difference between wifli and standard are as I remember a 5mm longer body, (not just the cage is longer), the distance between the pivots is increased to clear the larger cogs. It has been argued whether a short is 'crisper' than wifli, I couldn't feel it, but to some folks, they have that ability, I don't.
-adjustments - in these days of mass production, it should be cool, maybe a tweak. Don't forget to check/reset the b-screw for clearance.
In my adventure I built the bike, ran a few hundred miles and figured I needed MORE gear, had to flesh all this out found you can't just swap cassettes and I ended up with the RD, cassette, and chain leftover-sitting on my bike bench.
I hope that this helps.
