1 - 14 of 14 Posts
a$$hole
I absolutely love my EC90 SL carbon clinchers. I've also decided to start training using power. So after considering my options I've decided to buy a Powertap Pro+. Was going to have it built up around a Kinlin 270, but I think I've decided I'm going to have my EC90 SL carbon clincher built up around the Powertap.
Bad idea? Good idea?
a$$hole
wetpaint said:
Have you considered getting a Quarq or SRM? That way, you can run any wheel you want.
Considered it, but after consideration I decided a PowerTap was the better option for ME, PERSONALLY.
I think it's a great idea. You are ahead of the game. Trying to keep the budget as low as possible finding one wheel you like enough to race and train on is smart. I wish I would have done the same when I bought my powertap. I'm using the EA50 but if I could do it over I might do the EC90SL-c or a deeper Edge/Enve. I was unsure of the carbon clincher durability and chickened out.
a$$hole
Woody, I would actually use an Edge but I'm on a budget and just bought the EC90SL-cc set 2 months ago so that set me back a bit. I should have built the Powertap two months ago, but I didn't. So I'm working with what I have. I absolutely love my Easton set, so I figure I'll use the rear and replace the hub with a Powertap. Then I'll have a nice wheelset and with the Powertap Pro+ laced up to the Easton EC90SL Carbon that should provide me a wheel that is trainable AND race worthy...which is exactly what I'm looking for.
I am happy for you man! PT Pro+ and EC90 is a dangerous combo and really as good as anything out there imho. Maybe I'll sell my EA50/PT Pro+ and my EC90 SLX to fund a similar build...damn you.:thumbsup:
a$$hole
Discussion Starter · #9 ·
Yeah Woody, I'm so stoked. Ron Ruff is doing the build for me, so I have complete confidence it will be right! I expect to get back a PowerTap Easton EC90-c as though it were built by Easton...if not a bit better?
My big thing going with the PowerTap is that I'm currently riding a Tarmac SL3. Just started doing road races the last couple of months, and I'm not willing to race the SL3 in cat 5 crits. I'm building up an Allez frame to race in crits in the spring, so with this wheel I can easily swap between bikes, race, and train. It's the perfect all rounder for me I think. :)
Smart. Something that helped me with the PT was reading "Racing And Training With A Powermeter" 2nd ed. by Allen and Coggan. The 16 week FTP and 8 week peak plans are a very good blueprint you can follow to train smart and keep you on target to reach your goals.
Good luck racing! Crits are a blast!
a$$hole
Discussion Starter · #11 ·
Thanks for the heads up Woody. I've just ordered the book you references from Barnes and Noble. I was going to start looking for a book to get started with, so thanks.
It will be very different for me once I'm actually doing a training "regimen." I'm not really used to having numbers to go by...at least not power numbers. I definitely think it's going to make a big difference for me.
How did the EC90SL with powertap build go? I'm leaning that way right now too but wanted to see what it's like before committing.
a$$hole
Discussion Starter · #13 ·
I had a horrible experience with the Easton carbon clinchers. Hubs were ****. Breaking spokes every time I turned around, and I only weigh 148-152 pounds. Two areas about an inch long in the rear wheel where the breaking surface warped. I eventually tossed the wheelset in the dumpster, literally. Then I had the PowerTap laced up to an ENVE .45 which ended up being PERFECT. I've not had a single problem with the ENVE wheel.
I've since relaced the ENVE up to a DT 240 and it's one of my race wheels. For power I'm using a Quarq, and I like it a lot. My Powertap is currently laced up to a DT 4450 and is my "spare" PM and is mounted on my "bad weather" bike.
oh man that sucks! I've never had any problems with mine (2011 version), and have about 1500km's on them and I weigh 170ish. Wanted to go with a power tap. Was it your Easton hub that caused all your issues? I'd be using a power tap G3.
1 - 14 of 14 Posts
