I guess you can assume that a compact crank will wear out faster, but that really isn't correct. They just give you a larger range based upon the rear. You can ride in exactly the same gear ratio and the number of crank revolutions will be exactly the same. For instance, a 50x20 yields a 2.5 ratio and a 53x21 yields a 2.52 ratio. Each time the rear wheel spins 2.5 times, the cranks up front spin once. You just need to use a smaller cog on the rear to accomplish this. Maybe, you can assume that the cassettes will wear out quicker, but I don't even think that would be a good assumption. Plus, if you wear out cassettes and chainrings, you will be doing a lot of riding and wear out way more tires than chainrings, cassettes, or chains.
As far as tubulars are concerned, I have been using them since I was 16 (i.e., when we were allowed to use them for racing as juniors), so for 21 years now. I know how to glue them on and I prefer them to clinchers, but that is just me. It seems like most people just use clinchers nowadays. Actually, even back in the day, tubulars were mostly only used by racers.
