I have developed a reputation among friends and relatives as someone that can fix almost anything, especially bikes. But I have been humbled. A close friend brought me a Balance MTB for a rebuild (steel frame); he is doing some computer work for me in exchange. The seat post was stuck and unfortunately there is about 7" down inside the frame. Here is what I tried to extract it:
1. Pulling on the seat, but the seat popped off.
2. Soaking several days in penetrating oil.
3. Turning the seat post with a pipe wrench. No movement at all.
4. Soaking in ammonia (a Sheldon Brown trick to remove Al Oxide).
5. Using a hack saw blade to cut the down inside of the post. I got too nervous with this when I got close to the frame and I think I stopped short. In any case I could not curl up the seat post like I thought I should be able to do. Perhaps the wall is too thick (~.125")
6. Put a pipe through the BB shell and mount two car jacks to it. I drilled a 3/8" hole in the post, slid a hardened steel bar through the post and tried to push the post out. I bent every bar I tried.
7. Same as 6 but I packed the seat tube with dry ice (-109F) first.
8. Same as 7 but with dry ice inside and a torch on the outside.
After several days of trying I called my buddy last night and told him I was done. I gave up, but I am still looking for a way out of this. Does anyone have any other ideas? The only things I can think of are:
1. Continuing the saw cut and risking frame damage.
2. Fixturing the frame in a drill press (which I don't have) and trying to drill the seat post thinner so that perhaps the saw cut will work.
