1 - 13 of 13 Posts
Banned forever.....or not
Spicy Dumpling
I'm sure it's very specially modified but still to take it apart and put it back together in < 4 minutes is impressive. Changing a plug in a modern car would probably take twice as long.
Frog Whisperer
VaughnA said:
................... Changing a plug in a modern car would probably take twice as long.
not once you got the engine out
Rub it............
When I worked for Honda, I could yank an engine in a Civic in about 35-45 mins
Frog Whisperer
a sad state of affairs if you have to do that to change spark plugs......
Rub it............
Spark plugs on a Honda 4 cyl. take 10 mins. They are right on top. A V6 is 20 mins.
Frog Whisperer
just kidding never worked on any Honda....but there are engines out there that you actually have to loosen motor mounts and jack the engine up a tad to get a plug out or so I've been told
Discussion Starter · #9 ·
I think that that was a mid 80's Mustang V6, and some V6 Chevy.
The Mustang, for sure....Loosen passenger side motor mount. Place plywood on scissors jack under oil pan, and raise engine 2 to 3 inches.
Frog Whisperer
sounds to me like some engineer should have been beaten senseless for that one.....
Soon to be banned
Field stripping your Jeep? Pretty cool!
The coolest part is they did it without power tools.
1 - 13 of 13 Posts
