Question: Do you need a special shim with a Thomson stem on a one inch steerer? Or does a normal shim do the job? Does Thomson make an inch stem?
You do need a shim which costs extra. Thompson says to use only their shim because of the way the pinch bolts snug the stem to the steerer tube.Farmpunker said:Question: Do you need a special shim with a Thomson stem on a one inch steerer? Or does a normal shim do the job? Does Thomson make an inch stem?
