1 - 6 of 6 Posts
RoadBikeReview Addict
...between regular pads, used on aluminum clinchers, and carbon pads, used on carbon tubbies, do you switch JUST the pads or did you purchase an extra set of brake shoes/housing and simply swap the entire pad mounted in the shoe/housing out? It seems the latter would be the way to go? If it matters, I'm running DA 9-sp calipers.
Thanks,
Juanmoretime
I have an extra set of pads so when I switch I just bolt them on. I pretty much leave the carbon wheels on one bike and rotate bikes but I will occasionally swap them and its a P.I.T.A. to change pads.
I recently replaced the Shimano CF type pads with CoolStop CF pads. The Shimano pads were stuck and removal was very difficult. I could have just cut the old pads away but I wanted to keep them since I am basically a pack rat. I would recommend having multiple pad holders if you are going to regularly change the pads since it would make the swap out much quicker.
I have been swapping yellow swiss stop pads for salmon koolstops when I go from carbon to alum wheels.
It is a PITA to get the swiss stops in & out. The Koolstops are so easy.
I want to get some extra pad holders but am looking for BTP carbon ones.
That aside I do have some koolstop carbon pads coming
( thanks Juan )
It would be great if they slide in & out as easy as their salmon ones I use for Alum rims. Then it would not be much hassle at all to swap pads.
1 - 6 of 6 Posts
